beth hatcliff
#1 Posted : Saturday, February 13, 2010 8:44:19 AM(UTC)
beth hatcliff
i need help my freezer on my side by side keeps defrosting all my food then my frigerater part gets hot spoils everything in it i have to take everything out of freezer take back panel off get blow dryer out unfreeze all the coils put back together then that lasts like 2 weeks then do it all over again losing all my freezer food and frigerater food not sure what is going on with it .i had to replace hose on back for my water ice despenser have not use it in like 2 years or more done that hose replacement got new filter for inside turned it back on then it was leaking water like crazy some where out of the filter part took it off put it back on with the half turn was doing the same thing need to know if i need new frig. of if this is going to work replacing parts or if it is going to do it again this is very up setting to go thru every 2 weeks:confused:
#2 Posted : Sunday, February 14, 2010 3:28:25 AM(UTC)
You probably have a bad defrost heater AP3183311. If the old one is black with a clear section, it's bad. Order it on this site, it will probably be replaced with a better two coil unit, just ask.
