kdeldridge
#1 Posted : Saturday, March 22, 2008 7:49:40 PM(UTC)
kdeldridge
My washer makes a horrible grinding noise during agitation and seems to skip during the spin cycle. I'm not sure where to start & what to check first....
#2 Posted : Sunday, March 23, 2008 1:23:58 PM(UTC)
Remove the washer cabinet. Remove the pump and the motor and check the motor coupling.
Remove both hoses from the drain pump and check for a foreign object inside.
Here are the break down diagrams for the Roper washer Model RAX4232KQ0 (model is similar to yours).
kdeldridge
#3 Posted : Sunday, March 23, 2008 4:13:33 PM(UTC)
kdeldridge
I checked it this morning and it has now stopped agitating. It still spins but makes the same noise. I removed the pump and motor. The couplings are fine and there is nothing in the lines...I'm stumped!
#4 Posted : Monday, March 24, 2008 12:01:53 PM(UTC)
Sounds like the gear case (aka transmission) gone bad.
- The part number for the gear case is AP3096209
kdeldridge
#5 Posted : Monday, March 24, 2008 6:01:51 PM(UTC)
kdeldridge
Is there anything else it could be? I put it back together and it agitates again, but still grinds and clicks when spinning out the water. Thank you so much for all your help Gene!
#6 Posted : Monday, March 24, 2008 6:57:57 PM(UTC)
Did you check the pump itself?
Run the washer on the spin cycle with the cabinet out to pinpoint the noise. Post your findings.
kdeldridge
#7 Posted : Thursday, April 3, 2008 5:51:49 PM(UTC)
kdeldridge
It sounds like it is something wrong with the agitator. I ran it on spin, it spins fine, but it makes a grating sound. I cant tell where the clicking sound is coming from though. I even tried manually turning the agitator and it makes the same noise. I removed the agitator and cant see any visible problems...is it possible that it could be stripped?
#8 Posted : Friday, April 4, 2008 5:24:56 PM(UTC)
While the agitator removed, check if the splines on the shaft are worn. Turn the transmission shaft to see if the same noise will come out. In both cases the transmission (aka gear case) is bad and has to be replaced.
If there is nothing wrong then probably the splines inside the agitator are worn and the agitator has to be replaced to solve the problem.
- The part number for the agitator is AP3114127
Guest
#9 Posted : Friday, January 19, 2024 1:49:34 PM(UTC)
Guest
Rank: Guest
United States
Splutch drive dudes!!
Guest (5)
Loud grinding noise during agitation (Washer Repair)
by pete172 10/5/2013 6:32:47 PM(UTC)
GE top load washer make grinding noise during agitation and spin, but work fine, just (Washer Repair)
by dchanson55 1/21/2013 4:11:28 PM(UTC)
Grinding noise during agitation (Washer Repair)
by Shadow99 5/13/2009 5:23:10 AM(UTC)
