PJB
#1 Posted : Thursday, April 3, 2008 5:06:30 PM(UTC)
PJB
The dishwasher pump won't stop running. There is no water in the tub. Issue began with loud "click" noise that was constant. Tried to "reset". This stopped "click" but now pump runs non stop. Have reset the circuit breaker in attempt to "clear the brain" to end the cycle...no luck, pump runs continuously. HELP!!
#2 Posted : Friday, April 4, 2008 4:14:52 PM(UTC)
In order to provide most accurate advise we need the complete model number of the dishwasher.
PJB
#3 Posted : Friday, April 4, 2008 4:51:44 PM(UTC)
PJB
Model gsd5630d00ww
Serial vv710454b
Thank You
#4 Posted : Friday, April 4, 2008 5:02:09 PM(UTC)
Most likely the problem is a bad sequence switch (#904 on the break down diagram).
- The part number for the sequence switch is AP2039701
Here are the break down diagrams for the GE dishwasher Model GSD5630D00WW
PJB
#5 Posted : Friday, April 4, 2008 5:35:39 PM(UTC)
PJB
Sorry for the omission
PJB
#6 Posted : Friday, April 4, 2008 5:38:27 PM(UTC)
PJB
Thank you for your advice. I will give it a try.
#7 Posted : Friday, April 4, 2008 6:14:08 PM(UTC)
Keep me updated, please.
GE Triton Quiet Power III. Draining- though not the piston nut assembly (Dishwasher Repair)
by maxweenus 2/1/2012 4:03:12 PM(UTC)
Dishwasher won't drain. GE Triton Quiet Power III (Dishwasher Repair)
by eddiep 11/10/2008 1:05:22 PM(UTC)
