Good question, call APP and see if they can help you out.
IT IS DONE!!! Just ran a test cycle and it is purring like a kitten! I can't remember it ever running this quite. Thank you all for your help. Sue
You use super glue to glue the boot back on the outer panel.
Congratulations Sue, that's great.
Glad you were able to get it fixed (just so you know, a lot of people, even professionals do not tackle that job) and thanks for the update.
Originally Posted by: sidfink43  Congratulations Sue, that's great.
Glad you were able to get it fixed (just so you know, a lot of people, even professionals do not tackle that job) and thanks for the update. Well, hello again. 5 months of working beautifully 3-4 loads a week. Tonight my bubble burst. Washer started making stange noise (not the briken spider sound) and the water is not pumping out in final spin. Had to take out load and off to the laundramat it went. I assume that it is the water pump, is there a way to be sure? Thanks, Sue
