kharwat
#1 Posted : Thursday, February 11, 2010 8:35:11 AM(UTC)
kharwat
I have a Maytag single built in oven model number MEW6530DDS and the Bake, broil and other functions buttons no longer work. Canncel and
Conv Roast still works.
Thanks for your help,
A.K
#2 Posted : Thursday, February 11, 2010 11:41:16 AM(UTC)
Open the control panel and remove the control panel ribbon cable from the control board.
Check the tracks in the ribbon cable for a hairline cracks, using a magnifying glass.
Clean the edge with a pencil eraser. Clean the connector on the board, using an electronic contact cleaner or isopropyl alcohol and a tooth brush. Make sure it's dry before reconnecting.
Reconnect everything and give it a try.
If it would not help, replace the control panel.
- The control panel Part number: AP4416920
kharwat
#3 Posted : Thursday, February 11, 2010 3:06:55 PM(UTC)
kharwat
It didn't work. The upper strip made a beaping sound when removed from the control pannel and the lower strip didn't do anything. Is itpossible that the strips are the problem? Do I need to replace the whole pannel or can I buy the strips only.
Thanks,
#4 Posted : Thursday, February 11, 2010 6:36:08 PM(UTC)
I'm assuming the ribbon cable is the part you called "strip". The ribbon cable comes as a part of the control panel and can not be replaced separate.
Guest (4)
