lyndle
#1 Posted : Thursday, April 3, 2008 4:15:09 PM(UTC)
lyndle
My washer keeps filling up with water until it overflow but will not start to wash. It will run the spin cycle when I move to it by hand. Can you help?
#2 Posted : Friday, April 4, 2008 2:51:23 PM(UTC)
The first thing I would do is open the control panel and check the how the pressure hose (clear plastic hose) is connected to the water level switch.
If it's loosen, drain all water before reconnecting the pressure hose.
