AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer runs for every when put on regular setting
You have been a member since:: 3/31/2008(UTC) Posts: 3
Dryer will not shut off when puton regular setting
Hi Lazer,
Did it heat?
Did the timer advance?
We need as much information as possible.
Yes it heats but timer does not advance already replaced timer and thermostat on vent
Checked out dryer motor and fan all seams working well also checked duct work not blocked thanks for you help any more suggestions would be greatly appreciated
Disconnect the vent hose from the dryer and run one or two loads without that hose.
Dryer Repair
