peach65
#1 Posted : Wednesday, February 10, 2010 9:30:46 AM(UTC)
peach65
I just replaced the water valve on my Amana side by side but I'm still getting the leak from the water line ( where you fill up your glass). I replaced the valve based on the postings I saw on this board but it appears that the valve was not the problem. Any idea on another reason for the leak?
#2 Posted : Wednesday, February 10, 2010 5:56:30 PM(UTC)
Every time after you replace the water filter or the water valve (in your case), you have to evacuate 3 to 4 gallons of water through the water dispenser to get rid of air inside the system. Did you do it?
peach65
#3 Posted : Thursday, February 11, 2010 4:27:18 AM(UTC)
peach65
Probably not that much yet. I will make sure I do that today. Thanks for the quick reply.
#4 Posted : Thursday, February 11, 2010 4:17:42 PM(UTC)
peach65
#5 Posted : Tuesday, February 16, 2010 6:34:19 AM(UTC)
peach65
I'm still having the problem with the leak even after more than 5 gallons have been used. Could it be a faulty water valve? I've removed it and reattached to make sure the connections were correct.
#6 Posted : Tuesday, February 16, 2010 8:05:42 PM(UTC)
Carefully remove the wires from the water valve solenoid. Check if it's still leaking. Measure the voltage at the wire plug. Post the results.
peach65
#7 Posted : Saturday, March 6, 2010 5:32:46 AM(UTC)
peach65
removed wires and still leaking. the leak has actually gotten worse
#8 Posted : Monday, March 8, 2010 12:59:13 PM(UTC)
Sounds like the water valve is the culprit. Possible it stuck open.
Guest (6)
