victor borcea
#1 Posted : Tuesday, April 1, 2008 4:58:46 PM(UTC)
victor borcea
We try to cook at 425 .what happen is the flames started for ~20 sec and after that go off for 1 min and start again for 20-30 sec and go off again its like that for 1 hour .everything works except this intreruption .We can`t cook nothing and i`m hungry pleeeeeese help. What is strange when the door is open the flames inside stay ON.Maybe i need a new sensor or something ...Appreciate your help.
fixtec90
#2 Posted : Wednesday, April 2, 2008 4:36:45 AM(UTC)
fixtec90
Are you sure the oven is lighting? Could you be seeing the ignitor glowing attempting to light the oven? Remove the floor of the oven to observe. Your ignitor requires 3.0+ amps to open the bimetal that allows the gas to flow on a consistant basis. At 2.5 amps ignitor glows but won't open the bimetal. If it glows but doesn't ignite the gas replace the bake ignitor. This is the most common issue with gas ranges. Good luck.
