ggrek123
#1 Posted : Wednesday, April 2, 2008 4:07:50 AM(UTC)
ggrek123
No water goes into the dishwasher. When I mannually put water in dishwasher and turn it on it goes into wash cycle and gets stuck there. It will drain if I lift the float in the bottom tray and hold it up. Tested water valve by removing from dishwasher and plugging into outlet (water comes out when I plug it in and stops when it is unplugged). Suggestions?
#2 Posted : Wednesday, April 2, 2008 8:53:01 PM(UTC)
Check if 120V is coming to the water valve while the control calls for water.
If there is no 120V then the control module has to be replaced.
- The part number for the control module is AP2804411
