Hello to everyone and thanks, I've already learned a bunch. We have the above model. The dishes were not getting clean. When I ran it, the pump would run but very little water came out of the lower spray arm and certainly didn't reach the upper arm. I checked everything I could and finally had a service person come in who said I needed a new pump.
I can order it and do the job but wanted to see if anyone had other ideas. Mainly the pump runs but doesn't appear strong enough. This seems odd as my simple thought is it should run or not run. If it's 'weak', could it be something else.
Thx.
THIS FORUM IS DEAD!!!!!!! |
I would remove the torq screws from the pump top and remove the half round chopper cover. You might find the input grate to this is clogged up. If the chopper is clogged, replace it and the check valve in the pump housing AP3152971 and AP3039186 Before replacing, make sure (by turning the chopper) it is engaged to the pump impeller. If everything ok, you might have a bad pump impeller, or a pump motor running backwards although rather rare for Kitchen aid. Pump # AP4434021
Thanks to both of you for your insight. denman, the documents were great and saved me much time.
Both of you were spot on with the diagnosis. The chopper screen was completely coated with stuff. After I cleaned it, it ran much better and the wife is now happy again! :D
Furthermore, after working at the bottom of the dishwasher, I have an even greater appreciation for the work you guys do. Not pretty stuff down there!
Thanks again.
marshallfla
You are welcome
Glad it worked out for you as I know how important it is to keep the wife happy. |
Per the tech aid, the chopper is clogged either due to a bad coupling to the motor impeller, or a bad check valve, a black,thin rubber piece in the pump housing next to the chopper.
Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Per the tech aid, the chopper is clogged either due to a bad coupling to the motor impeller, or a bad check valve, a black,thin rubber piece in the pump housing next to the chopper. Roger that. My parts store had to order that from another store and it should be in tomorrow so I can replace it and the chopper. Thx again.
It could have had a plugged screen on the chopper assembly. Originally Posted by: marshallfla ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hello to everyone and thanks, I've already learned a bunch. We have the above model. The dishes were not getting clean. When I ran it, the pump would run but very little water came out of the lower spray arm and certainly didn't reach the upper arm. I checked everything I could and finally had a service person come in who said I needed a new pump.
Thx.
