jerkman_12000
#1 Posted : Sunday, February 7, 2010 2:52:23 PM(UTC)
jerkman_12000
I have an Amana sdi25e1l side by side.The referigator get to cold even on lowest setting and puts ice in everything..everything else works fine.What do I need to Check?/ Thanks Dan
#2 Posted : Tuesday, February 9, 2010 2:29:14 AM(UTC)
Interior parts replacement parts for AMANA SDI25E1L Ref - SXS/I&W | AppliancePartsPros.com
First I would check that the freezer temperature is OK
Should be close to 0 degrees F
If OK
Check that the damper Item 23 in Section 11 is OK.
Could be it is stuck open and is not regulating the amount of cold air entering the fresh food section from the freezer.
Here are a couple good sites with info on troubleshooting etc.
http://www.applianceaid.com/frig.htmlhttp://
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
