timmy650
#1 Posted : Sunday, February 7, 2010 12:37:31 PM(UTC)
timmy650
I have a Maytag MEW6530DDS and the Bake and Oven Light buttons no longer work. Based on previous posts I guess I need to replace the control panel and have the appropriate part number. My question is how do I remove the control panel? I removed the 4 screws from the control panel trim panel and could remove that. Not sure what else I need to do in order to pull out the panel? Does the oven need to be pulled out first?
#2 Posted : Monday, February 8, 2010 6:44:47 AM(UTC)
timmy650
#3 Posted : Monday, February 8, 2010 10:43:54 AM(UTC)
timmy650
Denman,
thanks so much for the help!
weekendwarrior10
#4 Posted : Monday, November 1, 2010 8:46:14 AM(UTC)
weekendwarrior10
I guess because I don't have an account with "servicematters" I cannot access the links. Can someone suggest another link to information to pull the control panel off this oven? I have to replace the control board.
Thanks-
