FRANK66
#1 Posted : Thursday, March 27, 2008 12:48:29 PM(UTC)
FRANK66
Washer Won't Agitate. It Does Spin And Fill Up The Water. Motor Sounds Like Is Working. Agitator Spins Freely.
How Do I Remove The Agitator To Check The Agitator Coupler?
Thanks!
sonjatodd
#2 Posted : Friday, March 28, 2008 7:28:18 PM(UTC)
sonjatodd
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
jlittau
#3 Posted : Saturday, March 29, 2008 12:53:08 PM(UTC)
jlittau
Thanks!
Frank66
Too funny, it's my same problem! I pulled up on the agitator and it came right up. Now, I'm wondering if the freely-spinning plastic coupler is the culprit.
FRANK66
#4 Posted : Monday, March 31, 2008 6:42:17 AM(UTC)
FRANK66
If you have a similar GE model the agitator coupler is that plastic cup that attaches the agitator to the tranmission shaft. It has a screw on the top which you will need to remove in order to replace the coupler. The coupler will be around $5 and it protects your transmission so it doesn't break from excesive torque. Hope this helps!
FRANK66
#5 Posted : Monday, March 31, 2008 6:43:51 AM(UTC)
FRANK66
