plubbers
#1 Posted : Sunday, March 30, 2008 6:22:29 PM(UTC)
plubbers
The impeller attached to the motor (#AP2043550) is now rubbing on the steel cover in the front lower lefthand corner of the dryer.The motor seems to be ok, but the shaft has about 1/4 inch of play from front to back. Would the motor have to be replaced?
I am going to replace the 4 drum slides and rear drum bearing kit.
#2 Posted : Tuesday, April 1, 2008 12:02:49 PM(UTC)
Originally Posted by: plubbers Go to Quoted Post
...The impeller attached to the motor (#AP2043550) is now rubbing on the steel cover in the front lower lefthand corner of the dryer.The motor seems to be ok, but the shaft has about 1/4 inch of play from front to back. Would the motor have to be replaced?...
I'm afraid I did not get you right. When you said "impeller", which part did you mean:
The motor pulley
UserPostedImage
or
The blower wheel
UserPostedImage ?
If we are talking about the motor pulley, it has a screw which could be tighten.
If we are talking about the blower wheel - it also has a screw which could be tighten and if it would not help then it has to be replaced.
The motor shaft should not play and if it does - the motor has to be replaced.
- The part number for the motor (including the motor pulley) is AP2043550
- The part number for the blower wheel is AP2043548
Here are the break down diagrams for the GE dryer Model DPSF495GV0WW
F+P Dryer Motor Shaft Play (Dryer Repair)
by bb4u 5/2/2009 11:12:52 AM(UTC)
