2 Pages12>
jeffrey_benjamin
#1 Posted : Wednesday, January 27, 2010 2:16:55 AM(UTC)
jeffrey_benjamin
Hi to all I've got me a problem here where the suction pressure on this Carrier A/C 30 ton system reads 50 PSIG. Three compressors have been replaced already. The evaporator coil has been cleaned. Any suggestions ?:confused:
John @ Fischers
#2 Posted : Saturday, February 6, 2010 5:06:58 PM(UTC)
John @ Fischers
Whats the high side PSI ?
jeffrey_benjamin
#3 Posted : Saturday, February 6, 2010 9:10:10 PM(UTC)
jeffrey_benjamin
hi thanks for your responce hi side preaaure is 300 psi. condenser is clean & fans are ok. :confused:
John @ Fischers
#4 Posted : Sunday, February 7, 2010 2:30:49 PM(UTC)
John @ Fischers
ok, to clarify. Is this a 30 TON or a 3 Ton A/C Unit ?
jeffrey_benjamin
#5 Posted : Sunday, February 7, 2010 2:52:53 PM(UTC)
jeffrey_benjamin
carrier 30 ton A/c system
John @ Fischers
#6 Posted : Thursday, February 11, 2010 3:52:39 PM(UTC)
John @ Fischers
That high side psi is kinda high for a 50 psi suction pressure. What was the original problems that cause the first compressor to be changed, and is this a roof top unit?
herman stoehr
#7 Posted : Wednesday, February 17, 2010 12:02:47 PM(UTC)
herman stoehr
sounds like you have a restriction in the unit somewhere, i would see if there are any liquid line dryer thats plugged
hvac_hillbilly
#8 Posted : Friday, February 26, 2010 9:59:56 AM(UTC)
hvac_hillbilly
if this a 30 ton ac instead of 2.5 ton 30'000 btu ac i think i would look at the txv at the evaporator coil this sounds like it is not opening correctly make sure its sensing bulb has not come loose from the suction line please let us know what you are cooling with 30 tons of ac
Fastlanedan
#9 Posted : Tuesday, March 16, 2010 6:22:31 AM(UTC)
Fastlanedan
A model # and serial # would help.
You most likely has a restriction on the orifice, it is located between the header and the distributor.
hvac_hillbilly
#10 Posted : Tuesday, March 16, 2010 7:38:27 AM(UTC)
hvac_hillbilly
well if it has an orfice i doubt its a 30 ton unit either
it could have a txv or even cap tubes but im guessing restriction some where too
Guest (4)
2 Pages12>
