Izettia
#1 Posted : Saturday, February 6, 2010 9:28:26 AM(UTC)
Izettia
I am finding water on my floor when I use the dishwasher. It is clean (no soap) water, so it must be as it is entering INTO the machine, but can't figure out where or how.
#2 Posted : Saturday, February 6, 2010 11:41:46 AM(UTC)
Replacement parts for WHIRLPOOL DU810SWPQ0 Undercounter Dishwasher | AppliancePartsPros.com
Remove the kick plate and watch it to try and find the leak.
A flashlight and a small mirror help here.
The best mirror is the type auto mechanics use, like a dentists mirror only larger.
If you have to you could tape a small mirror onto a stick.
Find the drip and then follow the water trail till you find the actual leak.
richardselectric
#3 Posted : Saturday, February 6, 2010 11:45:06 AM(UTC)
richardselectric
you may lhave to pull the dw out of the cabinet about a foot to check the siphon break on the left side. there is a hose from the water valve to the top of the siphon break which could have a hole in it or be loose. also see if water is running out of the siphon break.
