fastgta
#1 Posted : Saturday, March 29, 2008 12:24:01 PM(UTC)
fastgta
We bought this new around 1994 and it's never given us any trouble. Within the past 2 weeks we discovered it's leaking water and collecting under the crisper, then leaking out the front of the fridge. I did a search and I believe a drain tube is frozen or clogged but can't figure out where it is or how to get to it! I took the cover off the temp controls in the Refrigerator section and confirmed that's where the water is coming from. Please help! Also - there's an adjustment screw on those controls that had a plastic plug covering it up but it's not labeled, can someone tell me what that's for? I really can't afford a service call right now and this sounds like such an easy fix. Thanks alot for any help in advance.
fixtec90
#2 Posted : Monday, March 31, 2008 6:52:10 AM(UTC)
fixtec90
If you keep a fairly clean freezer it should just be ice up. The easiest thing that you can do is unplug refer for 24hrs and leave the door open.
