naskar1
#1 Posted : Saturday, March 29, 2008 9:43:13 AM(UTC)
naskar1
:confused: Gas dryer will not ignite, even with replacement of the Ignitor Assembly. It does not appear that the ignitor glows when activated upon start-up of the dryer. :confused:
#2 Posted : Saturday, March 29, 2008 1:58:58 PM(UTC)
The first thing I would do is check for continuity the safety thermostat (#33 on the cabinet/drum break down diagram), the flame sensor (#79 on the burner break down diagram), and the cycling thermostat (#15 on the motor break down diagram).
If any of them is open - it has to be replaced.
- The part number for the safety thermostat is AP2152884
- The part number for the flame sensor is AP2142636
- The part number for the cycling thermostat is AP2106565
Here are the break down diagrams for the Frigidaire dryer Model FDG546RES0
