Recently I replaced the drum seal and one drum roller.dryer worked great for two weeks then nothing.Prior to that 5 years of excellent working order.I do have juice at the outlet,and think its a switch .,and need to know how to diagnose,.Thank you very much
Do you hear any noise when you push the start button? (does it hum or is it silent) i dont have a way to research your model but if it is a gas dryer then a likely suspect would be the thermal fuse (rectangular white fuse with two wires attached) if electric check the door switch for continuity
Thank you It was a minor electrical connection.
