water wont shut off after tray fills in ice maker
Most likely the water valve stuck in the open position. The correction is to replace the water valve. - The water valve Part number: AP3672839
Thanks we will give it a try
Originally Posted by: Gene Most likely the water valve stuck in the open position. The correction is to replace the water valve. - The water valve Part number: AP3672839
I have the same problem. Called a service tech who can't come until next week ( and $80 svc call) How difficult is it for the mechanically disadvantaged to change the dual solenoid valve. The fridge is 13 years old. Thanks.
Originally Posted by: matt3161 I have the same problem. Called a service tech who can't come until next week ( and $80 svc call) How difficult is it for the mechanically disadvantaged to change the dual solenoid valve. The fridge is 13 years old. Thanks. What is the complete model number of the refrigerator? If you know how to handle a simple tools, this part is not too difficult to replace yourself. Gene.
Hotpoint, CSX27DR XAWW, 13 years old, thanks
Thanks, part is on the way and I will call for help if I need it, thanks again
