oldparts
#1 Posted : Friday, March 28, 2008 4:53:32 PM(UTC)
oldparts
Today the washer quit agitating and the water would continue to run (actually over flowed) not drain. Move timer (all seemed Normal like timer was good) And water would stop and it would drain/spin still no agitator,
Is there something that if agitator dogs go bad the water won't stop???
Or Maybe the timer itself?
fixtec90
#2 Posted : Saturday, March 29, 2008 4:05:44 AM(UTC)
fixtec90
When you say "still no agiatate" do you mean after stopping and restarting the timer with the tub full of water it starts filling again? If that's the case you have a pressure issue. Remove the pressure switch hose and closely inspect for pinholes, rips, and tears. Replace if needed. If the hose is intact replace the pressure switch Test several times after repair by filling to each water level. Agiatator doggs cannot make a washer overflow. If doggs are good you should only be able to spin the agiatator in one direction by hand.
oldparts
#3 Posted : Saturday, March 29, 2008 7:47:42 AM(UTC)
oldparts
Well it appears the hose came off of tub is self So we'll see how it goes.
Thanks for quick reply
fixtec90
#4 Posted : Saturday, March 29, 2008 8:14:11 AM(UTC)
fixtec90
That should do it. Glad I could help.
