billjess1
#1 Posted : Friday, February 5, 2010 8:50:32 AM(UTC)
billjess1
the weshing machine stays on the regular soil cycle and never moves to the rinse cycle unless i manually move the timer to the rinse cycle
#2 Posted : Saturday, February 6, 2010 12:54:11 AM(UTC)
A model number may help others help you.
Many units have a thermal hold, they wait for the water to be heated to a set point before continuing the cycle. Check the heater and thermostat with a meter.
If the unit has a cycle type that does not heat the water, try that.
If it now runs OK then a heating problem is your most likely cause.
the timer does not move (Washer Repair)
by billjess1 2/5/2010 9:00:55 AM(UTC)
