Cap-Cad
#1 Posted : Thursday, February 4, 2010 9:36:08 AM(UTC)
Cap-Cad
I have a Kitchenaid KUDI01FLSS3 disherwasher that no longer brings water into the unit at the beginning a cycle. LED lights activate after punching in the desired cycle, options, etc., but water never enters the unit and in a few seconds the lights go off. Every cycle has been tried, but still water never enters the washer. Float valve in basket is free and clear with no sign of hanging up. First part replaced to solve the problem was the inlet valve, but again, no luck. Question now is what's the next logical choice of a part to replace, Control unit or User Interface?
- Thanks
#2 Posted : Friday, February 5, 2010 3:47:15 AM(UTC)
Replacement parts for WHIRLPOOL KUDI01FLSS3 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
[COLOR="Blue"]
Every cycle has been tried, but still water never enters the washer. Float valve in basket is free and clear with no sign of hanging up. First part replaced to solve the problem was the inlet valve, but again, no luck. Question now is what's the next logical choice of a part to replace[/COLOR]
I would say neither as throwing parts at it will cost you a small fortune.
Better to use a meter and narrow down the odds of replacing the correct part.
I am assuming that you have checked the water supply to the unit and it is OK.
First when in fill I would check across the water valve just to be sure it is not getting voltage. It is not unheard of to get a bad part right out of the box.
If no voltage.
Then check across the overfill switch. Just because the float is holding it closed does not mean that the contacts in the switch are closing.
If you have 120 volts across it then it is toast and needs replacing.
If no voltage then I would check the wires from the contol panel to the water valve/overflow switch for continuity.
If OK then you could try diagnostics.
My guess would be that the control board is gone as the unit does seem to run the cycle correctly.
