Shayna
#1 Posted : Thursday, March 27, 2008 1:30:13 PM(UTC)
Shayna
I turned my washer on the other day and walked away only to discover a few minutes later my floor flooded. This just started suddenly. Now I have to stand by and manually turn the cold water off at the valve after filling up and back on and off again for the rinse cycle. The hot water will stop running into the washer when it begins to agitate, but the cold continues to run. Someone told my boyfriend that it sounded like the cold water solenoid valve. I am wondering if that could be the problem and also if that is expensive and if we could possibly fix it ourselves.
bambiblaster
#2 Posted : Thursday, March 27, 2008 4:17:13 PM(UTC)
bambiblaster
If tou unpuj the machine and the cold still comes in yes the inlet valve is bad.. Its not too hard to change... check this link for instructions
http://www.applianceaid.com/newlinks.html
toniarose
#3 Posted : Thursday, February 11, 2010 2:57:41 PM(UTC)
toniarose
Sounds just like the problem with my crosley conservatorHelp me.Tonia
washer won't stop filling with water and go to wash cycle (Washer Repair)
by dawn spoores 1/24/2011 8:02:54 AM(UTC)
washer won't stop filling with water (Washer Repair)
by oerck157 6/2/2009 9:19:48 AM(UTC)
Roper washer won't stop filling with water (Washer Repair)
by jeffct 11/11/2008 10:57:49 AM(UTC)
