2 Pages12>
allansc
#1 Posted : Tuesday, July 31, 2007 9:23:59 AM(UTC)
allansc
Gene,
My Whirlpool dryer runs,but won't heat.I have checked the heating elements(coils),don't see a break in them.I also checked to see if the venting is clogged,no problem there.
Any suggestions?
Thanks,
Allan
ApplianceJunk
#2 Posted : Tuesday, July 31, 2007 11:34:27 AM(UTC)
ApplianceJunk
Check this out,
Video: How to check voltage at cord on a Maytag electric dryer.
The video show how to check a maytag dryer, but every electric dryer is this way.
Admin / APP Team
#3 Posted : Tuesday, July 31, 2007 3:51:40 PM(UTC)
Admin / APP Team
Rank: Administration
Allansc,
Also check the thermal fuse for continuity with an ohmmeter. Open=bad, closed=good.
The fuse is number 19 on this diagram
Inexpensive volt/ohmmeters
ApplianceJunk
#4 Posted : Tuesday, July 31, 2007 4:03:13 PM(UTC)
ApplianceJunk
Go for the digital multi-meter.
They are much nicer to use.
Warren
#5 Posted : Thursday, August 9, 2007 1:21:37 PM(UTC)
Warren
How do you get to that part to check the condition?
Warren
#6 Posted : Thursday, August 9, 2007 1:22:10 PM(UTC)
Warren
Sorry - the thermal fuse?
Admin / APP Team
#7 Posted : Thursday, August 9, 2007 3:56:07 PM(UTC)
Admin / APP Team
Unplug the dryer and remove the back panel. You should then see the thermal fuse right on the blower housing. Make sure to remove one wire from the fuse before testing.
mark mazurkiewicz
#8 Posted : Monday, August 27, 2007 6:38:44 AM(UTC)
mark mazurkiewicz
Whirlpool gas dryer LGQ9557KQ0 heats on start up but flame does not come back on after.
I cleared the lint housing, checked the orifice . . . appeared fine.
I was checking the parts illustration and saw the internal thermostat bias AP3045874, the T-stat-hi-limit AP3084674, and I read the threads on checking the thermal fuse AP3132867. I'm trying to diagnose or troubleshoot. Would the thermal fuse do that and what do the other 2 items affect?
I just measured continuity across my thermal fuse . . . eliminate that as a possiblity.
Thanks,
Mark
Warren
#9 Posted : Monday, August 27, 2007 6:51:20 AM(UTC)
Warren
Make sure you check each (potential) electrical fuse, thermostat, heating coil for continuity. You'll need a multimeter to do this. (Radio Shack -$29). I found a $11 thermostat bad. This did the trick. Give this a try. Make sure the dryer is unplugged when you check for continuity.
Admin / APP Team
#10 Posted : Tuesday, August 28, 2007 8:53:28 AM(UTC)
Admin / APP Team
Mark, the valve coils are probably bad and only work for the first heat cycle. I'd try replacing the coils.
- Replacement coils for Whirlpool gas dryer
- Breakdown diagrams for Model LGQ9557KQ0
Guest (5)
2 Pages12>
