Wauseon
#1 Posted : Wednesday, March 26, 2008 5:45:15 PM(UTC)
Wauseon
Not sure of the exact model number. The sticker is missing from the inside of the door. Owners manual lists EDW2020,30,50,60, GSD 5110, 12, 20, 20, 32, 14, 24, 34, GSD5310, 20, 30, 50, 60. Problem started of as intermittent. Had a repair guy come out an look at. He suggested the control board was bad and we would be better off buying a new dishwasher. I replaced the control board and it still did not drain. Then checked the drain tube to the disposal. It appeared to be about 75% plugged on the disposal end. Replaced the hose and it still did not drain. I think the hose got plugged/dirty during the 2 month we did not run the dishwasher but continuted to use the disposal. Then pulled the drain pump. It appears to run ok when you apply power to it while it is sitting on the bench. I can feel it vibrating when it is going through the drain cycle. Then replaced the check valve assembly and it still does not drain. Then opened the door during the drain cycle to ensure the spring loaded valve was down and water was available to the drain side during the drain cycle. I'm confused! Help.
#2 Posted : Thursday, March 27, 2008 12:22:26 PM(UTC)
Did you see any blinking status indicator lights during a cycle or at the end of it?
Wauseon
#3 Posted : Thursday, March 27, 2008 2:19:31 PM(UTC)
Wauseon
I stopped it last night during the drain cycle. If I close the door and hit the start/reset button the pump will come on and the start/reset light blinks.
#4 Posted : Thursday, March 27, 2008 2:31:16 PM(UTC)
The control board has some self diagnosis options and the status indicator lights are blinking it could tell you what is wrong.
The start/reset blinking light is normal if you interrupt the cycle.
Wauseon
#5 Posted : Monday, March 31, 2008 2:48:21 PM(UTC)
Wauseon
I ran it through the rinse cycle only and did not see any blinking lights at the end of the cycle. Iam going to pull the drain pump again and see if I can get it to pump water.
Wauseon
#6 Posted : Monday, March 31, 2008 3:38:03 PM(UTC)
Wauseon
The pump pumps water when it is on the bench. Still confused.....
Wauseon
#7 Posted : Monday, March 31, 2008 4:12:48 PM(UTC)
Wauseon
I think it is the pump. It will push water through the check valve assembly in to a bucket but it will not push it through the drain hose.
fdimino
#8 Posted : Wednesday, November 2, 2011 2:20:38 PM(UTC)
fdimino
I have a blinking drying light. Is there a list of these codes somewhere?
#9 Posted : Thursday, November 3, 2011 12:33:01 PM(UTC)
Most likely the problem is a bad sequence switch (#904 on the diagram).
- The sequence switch Part number: AP2616983
Guest (6)
GE profile dishwasher won't drain completely (Dishwasher Repair)
by nazia 2/25/2014 5:52:10 AM(UTC)
GE Profile Dishwasher won't drain (Dishwasher Repair)
by tms101 9/14/2013 9:47:52 PM(UTC)
GE Profile Dishwasher Won't drain comletely (Dishwasher Repair)
by amyg5576 7/13/2012 5:52:19 AM(UTC)
GE Profile dishwasher won't drain completely (Dishwasher Repair)
by wcimo 3/12/2011 9:52:39 AM(UTC)
GE profile dishwasher won't drain (Dishwasher Repair)
by tlp385697 6/23/2010 6:26:33 AM(UTC)
by teetime 12/5/2008 8:44:58 AM(UTC)
