We have a bathroom wall heater that doesn't work because the coils that heat up have broken due to age. It has the name Fasco Industries in Fayettville NC on it and we have tried to contact them with no results or find a replacement and can't seem to. Can these coils be replaced or repaired or do we need to replace the heater? :confused:
Thank You
Judy Testa
More than likely your probably better off to replace the heater. You could however pull the element out and re attach it, but that would be kinda tuff.
Might be able to find a re-string kit for it also @ your local appliance shop, but doubt full.
