WILAUS
#1 Posted : Thursday, March 27, 2008 10:24:22 AM(UTC)
WILAUS
The Dishwasher Fuse Blew. I Replaced It And Used The Washer Again For A Few Weeks And It Blew Again. Examining The Circuit Control Board Which Was Higly Discolored (burnt) At The Connection For The Dishwasher Drain Pump. Upon Reviewing The Very Detailed Schematic And Found Out That The Motor Resistance Was Noted At 16.3 Ohms. My Motor Was Showing A Resistance Of 23.3 Ohms. This Is 50% Higher Than The Specified Resistance. I Went To An Appliance Dealer That Had A Pump Of A Different Design That Was Exactly 16.3 Ohms. I Wanted A Pump That Was Exactly Like The One Installed. I Just Received A New Pump That Is An Exact Replacement, But Its Resistance Is Also 23.3 Ohms. What To Do?.
fixtec90
#2 Posted : Thursday, March 27, 2008 11:12:01 AM(UTC)
fixtec90
Fuse will continue to blew if wires aren't replaced per instructions that come with the replacement fuses. If you didn't replace the wires to the fuse that is why it keeps blowing on you.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
