2 Pages<12
Dr_Zoidberg57
#11 Posted : Tuesday, February 2, 2010 12:31:44 PM(UTC)
Dr_Zoidberg57
John;
As far as I could tell, no signs of any obvious cracks as depicted in the photos you posted. The burners themselves looked remarkably clean and also showed no signs of any obvious defects. I carefully vacuumed out any dust and loose debris and then made sure everything worked.
Unless you see any reason not to, I'll go ahead and order the circuit board from the venue we discussed.
Gerry
John @ Fischers
#12 Posted : Tuesday, February 2, 2010 3:53:33 PM(UTC)
John @ Fischers
Sounds good! Yea, go ahead and carry on and get the board. let me know when we need to move further.
Dr_Zoidberg57
#13 Posted : Tuesday, February 2, 2010 10:19:11 PM(UTC)
Dr_Zoidberg57
Okay, I went ahead and ordered the board from the auction site that shall not be named. I will of course seek your wise counsel should I run into any difficulty installing it. I'm just guessing but unless they use a local parts distibutor, I probably won't get it until the first part of next week.
It may be redundant but much obliged for your assistance.
Gerry
John @ Fischers
#14 Posted : Friday, February 5, 2010 4:24:26 PM(UTC)
John @ Fischers
No problem, glad i can help.
Dr_Zoidberg57
#15 Posted : Friday, February 5, 2010 5:13:50 PM(UTC)
Dr_Zoidberg57
How fortuitous that you posted when you did beacuse I just finished installing the new circuit board. I labeled each wire using a small peice of tape before I removed it from the old board. It took a bit of coaxing to pull the wire off the old board but the rest of the job went smooth. I just completed running a test and everything works as it should.
Thank you for all your help.
Gerry
John @ Fischers
#16 Posted : Saturday, February 6, 2010 2:12:42 PM(UTC)
John @ Fischers
Awesome! Glad it all worked out. Very good idea on marking the wires. I have been doing it 18+ years now, and i still label on some.
Glad it is working good, and I'm very happy to help. Any more prob's, you can email me , or post back here.
And thanks for the update!
2 Pages<12
