kirks
#1 Posted : Tuesday, February 2, 2010 1:05:30 PM(UTC)
kirks
I am replacing the thermal fuse on the dryer. Do I also need to replace the high limit dryer thermostat so the thermal fuse doesn't blow again?
#2 Posted : Wednesday, February 3, 2010 2:01:18 AM(UTC)
Replacement parts for WHIRLPOOL LER7646EQ0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203401735.pdf
Depends on which one you are replacing, there are two in this unit.
For the one on the blower NO.
Just be sure to clean/check your vent system as this is the most common cause of it blowing.
For the one on the heater PERHAPS.
You have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check the seal (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
Whirlpool Dryer thermal fuse (Dryer Repair)
by tiffrenee79 4/28/2015 4:09:58 PM(UTC)
