I have a side by side that just started making a noise when the door is open. The lights are also flickering at a very low intensity, barely lighting the filaments. Unscrew the bulbs and the noise goes away. Sounds kind of like a relay hung up. I am comfortable working with electrical circuits. Any ideas? Everything else seems to be working fine.
A model # will help know what you have. I was wondering if you have the model, that has the board in the bottom back next to the compressor. It is held in by two screws, and is inside of a white plastic case. Check it out. If not give us your model #. Tom ApplianceEducator.com
I have whirlpool side-by-side, Model GD55HAXZNQ00. Open the door one day and the light bulb was flickering at a low level and making a buzzing sound. I took the bulb out and the sound stopped. I thought is was bulb problem. I bought a new bulb, put it in, and it did the same thing? Any suggestions?
