The oven has a new element and sensor. It takes 45minutes to heat up to 350. What else is a probable cause ?
Hi Alan,
Did the Bake heat element get red?
Gene. No it never went red at all. 45 mins to get to 350 seems to long for me so I changed the element and sensor. no luck it did the same.
Hi Allan. Most likely the problem is a bad electronic control board, but before you replace it I would recommend to perform the troubleshooting as described in the tech sheets (page 2). - The part number for the control board is AP3025959 Here are the break down diagrams for the Kitchen Aid range Model KEDC205YBL0Gene.
Thank-you for the info my friend.
Alan
