Our dishwasher is not working properly. The top arm is not spinning, thus the dishes are not being cleaned properly. Just a simple troubleshoot, I started the top rack wash only and set the arm in position, waited about ten minutes into the wash cycle, and the arm was in the same position. It did have water dripping down, but apparently not enough to make the arm spin. I believe the amount of water pressure is somehow reduced, thus not causing the arm to spin. Any suggestions???:confused:
THIS FORUM IS DEAD!!!!!!! |
