mark floro
#1 Posted : Friday, January 29, 2010 9:29:57 AM(UTC)
mark floro
Water is freezing at bottom of evaporator coil in the chill box side of refrigerator; water is not draining out of drain tube underneath coil tried to blow out drain tube and use hot water and hair dryer and no air is passing through fan motor is working fine it has been replaced with a new one compressor is working fine
mark floro
#2 Posted : Friday, January 29, 2010 9:35:01 AM(UTC)
mark floro
Originally Posted by: mark floro Go to Quoted Post
Water is freezing at bottom of evaporator coil in the chill box side of refrigerator; water is not draining out of drain tube underneath coil tried to blow out drain tube and use hot water and hair dryer and no air is passing through fan motor is working fine it has been replaced with a new one compressor is working fine ice is built up behind the panel for the evaporator fan
#3 Posted : Friday, January 29, 2010 11:37:32 AM(UTC)
The drain tube is clogged. No doubt about it. Check the other end of the drain tube.
Here are the breakdown diagrams and Replacement parts for MAYTAG RS265LABP Ref - Sxs | AppliancePartsPros.com
