Dave Martin
#1 Posted : Thursday, January 28, 2010 6:40:43 AM(UTC)
Dave Martin
I reviewed a thread on this site that suggested removing the lower spray arm to start the process of troubleshooting a leak under my machine. I cant loosen the spray arm. I am trying to turn it in a clockwise motion. Is that correct? Do you have a link that discribes reparing pump seals on this model?
Thanks for any help
#2 Posted : Friday, January 29, 2010 2:03:01 AM(UTC)
Here is your parts breakdown
Replacement parts for General Electric GSD500X-73WB | AppliancePartsPros.com
If you click on the picture you should be able to get a better view of it.
Looks like a standard thread to me so you should be turning it counter clockwise.
Just in case it is a newer type, check out the following link under Ge units and then #16
http://www.applianceaid.com/dishwash.html
I personally would troubleshoot a leak differently.
I would remove the kick plate and then using a flashlight and a small mirror locate it from the bottom. A good mirror is the type used by auto mechanics sort of like a dentist's mirror only larger. This is not absolutely required, it depends on where the leak is. Also just taping a mirror to a stick works.
Be sure to look higher up from where it is dripping as the water will run down and where it drips in not where the actual leak is.
Dave Martin
#3 Posted : Friday, January 29, 2010 5:08:43 AM(UTC)
Dave Martin
Thanks for your reply and info. I had previously done the troubleshooting proceedure you described and the water appears to be coming down through the connecting collar and then down through the motor. I believe I have to get the sprayarm out before any other disassembly can be attempted.
#4 Posted : Friday, January 29, 2010 6:14:37 AM(UTC)
Not much on the pump in the following but it may help.
http://appliancejunk.com/ge/dishwasher/31-3280.pdf
Dave Martin
#5 Posted : Friday, January 29, 2010 1:27:22 PM(UTC)
Dave Martin
Thanks for sending.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
