djramb2
#1 Posted : Friday, March 21, 2008 7:13:08 PM(UTC)
djramb2
I boiled and softened King Crab legs and chopped the shells and fed them into my garbage disposal. The blades spin perfectly, but the water will not go down. I have tried vigariously plunging (hand plunger) many times with no results.
Any suggestions?
bambiblaster
#2 Posted : Saturday, March 22, 2008 4:19:01 AM(UTC)
bambiblaster
you need to turn off circuit breaker to disposer and remove drain pipe that comes out of it and clean out the clogg
djramb2
#3 Posted : Saturday, March 22, 2008 5:04:46 PM(UTC)
djramb2
Thanks for your advice! I was hoping to avoid removing the drain pipe. To that end I continued plunging for a very long time rather than removing the pipe. The clogg did finally move with plunging.
thanks
