dwclli
#1 Posted : Wednesday, January 27, 2010 5:33:43 PM(UTC)
dwclli
Can you tell me what the reset procedure is for my Whirlpool Dishwasher: Model #DU1100XTPTA ? I understand it is the cancel button and maybe just one more???????
dwclli
#2 Posted : Wednesday, January 27, 2010 6:47:55 PM(UTC)
dwclli
I read more posts and found 2 with the following instructions:
Try pressing normal wash -heat dry-normal wash-heatdry- normal wash-heat dry- norma wash - heat dry. all the lights should come on. then after a little bit. keep pressing start till disher washer gets back to normal shut down.
what happen your water was to cold going into the disherwasher one time taking to long to warm up. the dishwaher went into a fault mode. the light blinks 7 times because there was a fault with your heater circuit. this should take care of it.
UserPostedImageUserPostedImageUserPostedImageUserPostedImage
THEN I tried it and PRESTO, this suggestion from a senior APP, and another individual, was just what was needed!! My dishwasher is running!!!! sounds like "music" after all these months of SILENCE, and 7 blinks after another, after another, after another!!!!! THANK YOU for your posts and for whoever is responsible for this site. THANK YOU!!!!!
pmshah
#3 Posted : Tuesday, February 7, 2012 2:59:23 PM(UTC)
pmshah
This post is very useful. Thanks for all who took time and explain the problem. My whirlpool dishwasher GU 2800 XTVY, was not starting. So i tried to reset, pressed normal button and heat dry button 4-5 times, and all lights will turn on. This is reset. Then press the start button and dishwasher was working again.
Thanks again.
jce
#4 Posted : Friday, July 4, 2014 8:20:01 AM(UTC)
jce
Thanks again.
Very useful post. Had to replace a pump sump unit and would not run until I reset, pressed normal button and heat dry button 4-5 times, and all lights will turn on. Was about to take out the thermal fuse until I found this.
Thank you
JCE
