02Lightning
#1 Posted : Friday, March 21, 2008 6:59:09 PM(UTC)
02Lightning
Hello, When I get a glass of water from my side by side whirlpool it dispenses fine but when I'm done a pull my glass away I hear a tick tick tick and it drips water out for a few seconds. How do I fix this?
#2 Posted : Saturday, March 22, 2008 1:47:56 AM(UTC)
Probably a water solenoid going bad. Pull the back panel and measure the water solenoid voltage, (the solenoid that activates the 5/16 line) while someone pushes in the fountain water button. Valve should stop water as soon as voltage goes away, if not replace it. They sell a good kit for this P#
4318046. Just make sure you do not get the valve type with the push on water lines.
02Lightning
#3 Posted : Saturday, March 22, 2008 6:32:12 AM(UTC)
02Lightning
when you say pull the back panel, where would that be behind the door or refrigerator?
Thank you!
