2 Pages<12
geoffrey@pollich.com
#11 Posted : Tuesday, January 26, 2010 10:53:50 AM(UTC)
Dave,
You have to remove the outer door panel and screws holding the dispenser.
Where does one locate the "screws holding the dispenser" Also - the plastic door gurads (or whatever they are) fell out when I removed the cover - where do they attach?
#12 Posted : Tuesday, January 26, 2010 10:55:27 AM(UTC)
You have to remove only side screws. I'm not sure how many of them are for your model.
There are 3 down each side - only remove these - the 4 along the top hold the control panel in place
#13 Posted : Monday, July 12, 2010 4:32:28 PM(UTC)
Originally Posted by: crosney Go to Quoted Post
I have a Bosch SGS3042GB/01 and need to replace the soap dispenser. I'm not clear from your description which screws to remove to take off the outer door. There are 3 torx screws on each side (and four along the top) facing from the machine interior to the outer door (i.e. perpendicular to the door); there are also 3 torx screws on the sides of the interior of the inner door running parallel with the plane of the door. Sorry for the convoluted explanation, but I am unclear which to remove. The ones perpendicular to the door look most promising.
The model number you posted is for a Thermador stove. Verify and repost it, please.
#14 Posted : Tuesday, July 13, 2010 7:16:45 PM(UTC)
Well, now I see. The link you posted leads to the UK web site and the model number you posted is UK model. That's why it does not come up on any US appliance web sites.
Unfortunately we are not able to supply anybody with more or less reliable advices for non American models.
Guest (4)
Bosch detergent dispenser won't open (Dishwasher Repair)
by ScoutB 11/27/2010 8:36:24 PM(UTC)
2 Pages<12
