The Lights On The Ice&water Dispenser Dim, But Not Dispensing Anything.hrs Is Lit Up On Control Panel. The Motor Is Not Running While The Lights Are Flashing And The Rest Of The Display On Control Panel Is Blank, Clicking Noise Heard .i Unplugged It But Did Not Help, Didnt Run All Night&then It Started Running Again This Morning Is This A Common Problem , If So What Is It Thanks
Any Help Would Be Appreciated
