I have a Kitchenaid gas range and the oven door handle is loose. I can see it has two screws on each end of the handle, but the screws are mounted from inside the oven door. I need to open the oven door to tighten the screws, but can't figure how to take it apart.
Hi, On my Wirlpool stove/range (model #Rf375PXDN O) I did it this way. Open door to stove. Locate two screws on top edge of door. Remove screws. Front door panel will rotate toward you and away from the interior door panel. This will allow access to two hex head fasteners at parallel distances consistent with the outside door handle. Use a pliers, hex head nut driver or wrench to tighten them. Push the front door panel back to its original position and replace the two top door screws. It was that easy! Good luck, Dave
