Eric Kelsheimer
#1 Posted : Friday, August 24, 2007 9:05:45 AM(UTC)
Eric Kelsheimer
I need to know how to replace the drive belt on my Kelvinator AW300G clothes washer. I cant figure out how to access the belt.
#2 Posted : Monday, August 27, 2007 8:28:14 AM(UTC)
Hi Eric Kelsheimer
In order to get an access to the drive belt you have to remove the front panel from the washer.
Remove two screws from each side on the bottom of the front panel. Using a putty knife or a flat screwdriver push the front panel from the top downward to release it from the locking tabs and pull it out.
- Here are the break down diagrams for the Kelvinator washer Model AW300G1W
Good luck.
