My dishwasher does not take any water but everything else works.Plz someone hekp me.
Sounds like the water check valve is stuck or your pump is bad any more info would be good
whot you need for more info.
Originally Posted by: billyquiet  Sounds like the water check valve is stuck or your pump is bad any more info would be good how i check this things
