Barbara D
#1 Posted : 17 years ago
Barbara D
My under the counter GE Profile trash compactor will not shut off nor will the "smasher" raise back up. When I turn it on, the motor runs until I manually turn it off. It is in the down position now so I can't open the door.
#2 Posted : 17 years ago
Hi Barbara,
In order to provide most accurate advise I need the complete model number of the unit. You can find it on the frame behind the drawer.
Barbara D
#3 Posted : 17 years ago
Barbara D
Hello, the model # is ZCG3300VWW
We have tried to remove the kick plate and the panel at the top to access the screws to remove it from the cabinet but no luck. Any suggestions?
Thanks,
Barbara
skeeter
#4 Posted : 17 years ago
skeeter
Barbara,
I am having the same issue, the chain has fallen off the sprocket. You will have to remove the access plate from the back of the unit then use a socket wrench on the sprocket nut to raise the ram. Then the door can be opened.
Use the same method to reattach the chain. My issue is the chain keeps coming off, new compactor, not even filled the first bag yet.
good luck...
