eds_warehouse
#1 Posted : Thursday, March 20, 2008 9:56:32 AM(UTC)
eds_warehouse
I have been trying to repair a Maytag Front load washer. Model Number MAH4000AWW. I have water pouring out of the door. I have checked the water valve....checked fine. I have checked the pressure switch...checked fine. I am lost at what to do next.
Bob N
#2 Posted : Friday, June 13, 2008 8:47:34 AM(UTC)
Bob N
You probably have figured out your problem by now, however, just in case you are still dealing with this problem, here is how I solved mine: the hose filter screen, located in the cold water hose on the end attached to the washer, probably needs to be cleaned out! That's what I did with mine and it works with no leaking now.
Just so I wouldn't have to pull the washer all the way out from the wall in the future, I put a hose filter in the cold water hose on the end attached to the faucet. Keep those filters clean and the leaking will end! Bob N
Maytag washer leaks on power wash cycle (Washer Repair)
by homeland1984 8/1/2020 8:44:37 AM(UTC)
Maytag Washer leaks at bottom tub seal (Washer Repair)
by Stilltrying 6/22/2015 5:52:31 PM(UTC)
Maytag washer leak (Washer Repair)
by joeblowsky 3/16/2015 12:10:39 PM(UTC)
Maytag washer leaking (Washer Repair)
by kpks26 2/5/2014 1:16:48 PM(UTC)
Maytag Washer Leaking (Washer Repair)
by scottlassy 12/11/2012 7:46:32 PM(UTC)
Maytag Washer Leak repaired, but resulted in loss of spin (Washer Repair)
by Repair Gone Wrong 2/21/2012 11:21:14 AM(UTC)
by kaclark7 2/20/2012 5:03:39 PM(UTC)
Maytag Washer leaks (Washer Repair)
by A00446849 2/20/2012 9:31:31 AM(UTC)
Maytag Washer leaks on side of drain hose (Washer Repair)
by della 12/17/2011 10:34:04 PM(UTC)
maytag washer leaks (Washer Repair)
by kramler92 12/7/2011 4:47:43 PM(UTC)
Maytag Washer Leaking Water into Tub (Washer Repair)
by mightypasta 11/21/2011 8:55:22 AM(UTC)
Maytag washer leak at tripod bolt (Washer Repair)
by rrando 5/19/2011 5:43:10 AM(UTC)
Another Maytag Washer leaky tub parts question (Washer Repair)
by sbracer 2/22/2011 1:40:18 PM(UTC)
Maytag Washer leaks at bottom (Washer Repair)
by ronf 10/23/2010 6:07:28 AM(UTC)
Maytag washer leaks on the bottoom (Washer Repair)
by Bummer plumber 9/9/2010 7:56:24 AM(UTC)
