I am in need of some advice on how to fix an older model (10+ years) whirlpool gas dryer. The dryer seemed to have quit during a drying session and now will not start back up. The dryer will "buzz" with the normal sound when depressing the start button, but dryer does not start up. Anyone have suggestions or ideas?
Check the door switch for continuity and if good remove rear panel and check thermal fuse on blower housing for continuity...
