My water dispensor for my KitchenAid side by side built in refrigerator works sporatically. Sometimes it takes a few seconds to get water and some times it won't dispense at all. Could this be a switch problem insttead of a motor problem? Any one else experience this type of operation?
Thanks,
Mike
sounds to me like the water inlet valve may be bad - before replacing it i would maybe wait for another opinion but i feel pretty confident replacing the water valve will fix your problem
Thanks. I'll try replacing the water inlet vavle. I appreciate you taking the time to reply.
Mike
