Wtaer is hot put high limit reset keeps popping. once reset heats water ffine but will pop again?
Originally Posted by: Rick1  Water is hot but high limit reset keeps popping. once reset heats water fine but will pop again? nnnnnnnnnn
Probably lower t-stat problem if your still popping top stat. if you can, actually measure the temp of the water, or maybe you notice the water is hotter than normal?
Check water temp. If too hot versus your settings, replace lower stat and monitor.
gas hot water heater flame sensor
(General Talk)
by normpete
1/21/2022 9:10:29 AM(UTC)
Electric Hot Water Heater
(Forum Announcements)
by paul gesche
9/7/2019 9:39:25 AM(UTC)
hot water heater
(Heating, Ventilation, and Air Conditioning (HVAC))
by johna56
12/26/2017 11:32:44 AM(UTC)
Ever decreasing hot water throughout house- Hot Water Heater
by Boiler20
6/30/2014 7:25:33 PM(UTC)
Hot water heater anticipator
by jbili
11/30/2011 3:46:02 PM(UTC)
Replacing gas hot water heater only for higher efficiency....
by Olives
7/21/2010 4:15:57 AM(UTC)
Gas Hot Water Heater Broken?
by bmyu
12/26/2009 6:12:22 AM(UTC)
40 Gal. Dual Element Electric Hot Water Heater
by Teager
9/11/2009 1:21:26 PM(UTC)
hot water heater
(General Talk)
by conjp57
10/17/2008 8:47:09 PM(UTC)
bosch tankless hot water heater
by artie in miami
8/17/2008 1:12:00 PM(UTC)
hot water heater
by angidale
8/12/2008 4:40:04 PM(UTC)
Hot Water Heater won't stay lit.
(General Talk)
by bulll
5/20/2008 8:51:10 AM(UTC)
wiring hot water heater
by kyle pennsylvania
12/29/2007 2:23:19 PM(UTC)
