janappo
#1 Posted : Sunday, January 24, 2010 10:39:23 AM(UTC)
janappo
We had our refrigerator problem diagnosed and it seems to be the thermostate to the freezer. If the refrigerator and feezer start cooling down we tap the control know area and it starts right up again.
Is part AP2151607 what we need and is it easy to install ourselves?
Thanks Anne
#2 Posted : Monday, January 25, 2010 12:38:25 AM(UTC)
That is the compressor control, the one on the left. If intermittant, it will stop the compressor. You should remove it and confirm by tapping on it.
If ok, describe the failure symptoms.
janappo
#3 Posted : Monday, January 25, 2010 12:32:12 PM(UTC)
janappo
Is This Part Easy To Install?
Thanks Anne Nappo
#4 Posted: : Tuesday, January 26, 2010 12:29:22 AM(UTC)
Yes, just plug the new one in and route the capillary line exactly as the old one, make a diagram if necessary.
